How do I configure UK numbering plan for CCM 6.0
allan.thomas Wed, 12/12/2007 - 14:35
  • Blue, 1500 points or more
Jeff, in addition to the previous post, please take the opportunity to review the document at the following link. Although it refers to 5.1.x to same will still apply, I could not find a document specific to v6.0:-
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00808b41cd.html
It provides details of where to find the DialPlan, and also detailed information on to install it in your CCM cluster.
Hope this helps.
Seasons Greetings
Allan.
g1smdvoip Thu, 01/12/2012 - 12:26
  • Silver, 250 points or more
That was quick! After informing Cisco of the above errors in November 2011, all the problems were fixed about 8 weeks later.
Both the referenced HTML page and the PDF document have been updated to incorporate all of the above changes and additions.
In other news, Ofcom recently (December 2011) issued an Errata to the UK National Telephone Numbering Plan correcting spelling mistakes for nine place names in the UK area code list.
Most of these errors were introduced in the April 2003 version of the number plan (though some of the errors existed before that time).
The corrected names are detailed at:  http://stakeholders.ofcom.org.uk/telecoms/numbering/  and below.
Area Code
Current Geographic Area Name
Corrected Geographic Area Name
01271
Barnstable
Barnstaple
01284
Bury-St-Edmunds
Bury St Edmunds
01286
Caernarvon
Caernarfon
01289
Berwick-on-Tweed
Berwick-upon-Tweed
015395
Grange-Over-Sands
Grange-over-Sands
01559
Llandyssul
Llandysul
01877
Callandar
Callander
01889
Rugely
Rugeley
01934
Weston-Super-Mare
Weston-super-Mare
g1smdvoip Fri, 12/02/2011 - 00:30
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008028af3a.shtml
http://www.cisco.com/image/gif/paws/45704/uk_numbering_plan.pdf
There's some errors in the above documents and the data is several years out of date.
Local Access
There is an error in the following text:
  In the UK, local subscriber numbers can be 5, 6, 7, or 8
  digits long, which depends on the area code. The UKNP contains
  four route patterns that overlap, for local access.
The text should read as follows:
  In the UK, local subscriber numbers can be 4, 5, 6, 7, or 8
  five route patterns that overlap, for local access.
Add "4,". Change "four" to "five".
There is an item missing from the table:
Number Route Pattern
LOCAL-5-DIGIT [2-9]XXXX
LOCAL-6-DIGIT [2-9]XXXXX
LOCAL-7-DIGIT [2-9]XXXXXX
LOCAL-8-DIGIT [2-9]XXXXXXX
Add the extra line at the beginning of the table as follows:
LOCAL-4-DIGIT [2-3]XXX
Add the new text "LOCAL-4-DIGIT [2-3]XXX" to the beginning of the table.
In the details after this text:
"For example, a gateway in a 2-digit area code with 8-digit subscribers has this filter:"
there is an error in the example code:
 (LOCAL-5-DIGIT DOES-NOT-EXIST AND
  LOCAL-6-DIGIT DOES-NOT-EXIST AND
  LOCAL-7-DIGIT DOES-NOT-EXIST)
The text should read as detailed below:
 (LOCAL-4-DIGIT DOES-NOT-EXIST AND
  LOCAL-5-DIGIT DOES-NOT-EXIST AND   LOCAL-6-DIGIT DOES-NOT-EXIST AND
Add "LOCAL-4-DIGIT DOES-NOT-EXIST AND" to the beginning of the example.
Extended National Toll Bypass
There are two errors in the following text:
  For example, calls from Reading (118) to Nettlebed (1491),
  Maidenhead (1628), Ascot (1276), Bracknell (1344), Aldershot (1252),
  Basingstoke (1256) and Newbury (1635) are charged at the local rate.
These two area codes changed name in 2003:
  • 01491: Nettlebed changed name to Henley-on-Thames.
  • 01276: Ascot changed name to Camberley.
  For example, calls from Reading (118) to Henley-on-Thames (1491),
  Maidenhead (1628), Camberley (1276), Bracknell (1344), Aldershot (1252),
Correct the names for these two area codes.
The following text is incomplete:
  The OR statements appear when you add a new Clause to the filter.
  See Appendix D - Five-digit Subscriber Numbers for lists of area
  codes with 5-digit subscribers.
The corrected text should read as follows:
  codes with 5-digit subscribers and Appendix E - Four-digit
Subscriber Numbers for lists of area codes with 4-digit subscribers.
Correct the text.
Appendix A - UK PSTN Numbering Overview
  The UK PSTN does not have a uniform structure like the NANP.
  Area codes can be 2, 3, 4 or 5 digits; subscriber numbers can
  be 5, 6, 7, or 8 digits; and service codes can be 3, 4, 5, or
  6 digits. National numbers can be 10 or 11 digits (including
  the leading 0).
  be 4, 5, 6, 7 or 8 digits; and service codes can be 3, 4, 5, or
  the leading 0) and there are two 8 digit numbers (0800 1111 and
  0845 4647).
Add "4,". Add wording about the two 0800 and 0845 special cases.
In the following text:
"These are the rules for geographic numbers:"
there are some minor changes to make towards the end of this list:
  •   2-digit area codes have 8-digit subscribers.
  •   3-digit area codes have 7-digit subscribers.
  •   4-digit area codes have 6-digit subscribers.
  •   Some 4-digit area codes have both 5- and 6-digit subscribers.
  •   5-digit area codes have 5-digit subscribers.
  •   Some 5-digit area codes overlap with 4-digit area codes.
The corrected text reads as follows:
  •   One 5-digit area code has both 4- and 5-digit subscribers.
  •   All 5-digit code areas overlap with 4-digit area codes.
The wording is changed in one rule and there is an additional rule.
Geographic Number Examples
Two examples are missing from the table:
Access Area Code Subscriber Place
0 16977 XXXXX Brampton 5-digit
0 16977 XXXX Brampton 4-digit
Add the above examples to the table.
The Brampton 016977 area code has both four-digit and five-digit subscriber numbers.
National Numbers
These new number ranges are missing from the table:
Access SABC Type Length
0 300/302/303/306/330/333/343/344/345/370/371/372 UK wide 11
Add this extra number range.
The following table entry contains an error:
0 55X/58X Corporate 11
The correction is as follows:
0 55 Corporate 11
Correct the data for this number range.
The following number ranges have changed since 2003:
0 77X/78X/79X Mobiles 11
This entry should read as follows:
0 71XX*/72XX*/73XX*/74XX/75XX/7624/77XX/78XX/79XX Mobiles 11
Add the new number ranges.
*Note: 71XX, 72XX and 73XX are not yet in service.
0 844/845 Local Rate 11
0 842/843/844 Special Rate 11
0 845 Lower Special Rate 11
0 870/871 National Rate 11
0 870 Higher Special Rate 11
0 871/872/873 Lower Premium Rate 11
There is no such tariff as "local rate". This entry:
  NHS Direct—08454647 (local rate)
should be reworded to something like:
  NHS Direct—0845 4647 (Lower Special Rate)
Correct the wording.
Service Numbers
This new number range is missing from the table:
Service Codes Services
116XXX National Helplines
Appendix B - Filter Categories
There is one example missing from the following data:
Category Numbers* Example
AREA-CODE
2, 3, 4, or 5 digits 20, 161, 1208
AREA-CODE
2, 3, 4, or 5 digits 20, 161, 1208, 15395
Add ", 15395" to the list.
There is an error in the following data:
SUBSCRIBER 5, 6, 7, or 8 digits -
SUBSCRIBER 4, 5, 6, 7, or 8 digits -
Add "4," to the list.
This new number range, allocated in 2009, is missing from the table:
NATIONAL-HELPLINES 6 digits 116123
LOCAL-RATE-ACCESS 844 or 845-
LOCAL-RATE-SUBSCRIBER 7 digits 7766554
NATIONAL-RATE-ACCESS 870 or 871 -
NATIONAL-RATE-SUBSCRIBER 7 digits 1112223
The new allocations are as follows:
LOCAL-RATE-ACCESS 842, 843, 844 or 845 -
NATIONAL-RATE-ACCESS 870, 871, 872 or 873 -
Add the additional number ranges.
Note: In the other Cisco UK Numbering Plan document, these are  referred to as: LOCALRATE-ACCESS, LOCALRATE-SUBSCRIBER,  NATIONALRATE-ACCESS and NATIONALRATE-SUBSCRIBER with only one hyphen.
Note: It is now illegal in the UK to use the terms "local  rate" and  "national rate" to describe these numbers in advertising as the price of  calling them is higher than calling a normal geographic number.
These new number ranges, allocated in 2008, are missing from the table:
UK-WIDE-ACCESS 30X, 33X, 34X, 37X
UK-WIDE-SUBSCRIBER7 digits222 3333
Add these new number ranges.
The following number type is missing from the table:
LOCAL-4-DIGIT 4 digits -
Add this extra data to the table.
These four-digit subscriber numbers are used in the 016977 area code.
Tag Combinations
The following tag combination is missing from the list:
  LOCAL-4-DIGIT
Add this tag data.
5-digit Area Codes with 5-digit Subscribers
The data for 5+5 format numbers is incomplete and some area codes are linked to the wrong place names:
Location Area Codes
Dumfries 13873
Hornby 15242
Kendal 15394 15395 15396
Wigton 16973 16974
Penrith 17683 17684 17687
Gosforth 19467
The corrected data is as follows:
Location Area Codes
Langholm 13873
Hornby-with-Farleton 15242
Hawkshead 15394
Grange-over-Sands 15395
Sedbergh 15396
Wigton 16973
Raughton Head 16974
Brampton 16977
Appleby-in-Westmorland 17683
Pooley Bridge 17684
Keswick 17687
Gosforth 19467
Correct the data for these number ranges.
4-digit Area Codes with Mixed 5-digit and 6-digit Subscribers
The following number ranges have changed since 2003 and should be DELETED from the table:
Location Area Codes 5-digit Subscriber Number Ranges
Forfar 1307 8[2-4]XXX DELETE THESE
TWO ENTRIES
Kircudbright 1557 50XXX
These area codes were upgraded to use only 6-digit subscriber numbers at least several years ago.
The following number ranges were mis-classified by Ofcom for many years and should be DELETED from the table:
Wigton 1697 7[23]XXX DELETE THIS ENTRY
This entry should show the 4-digit subscriber numbers found in the 016977 Brampton area code.
This data therefore belongs in a different table and in a different format: e.g. "16977 [23]XXX". See the final item.
Buxton 1298 2[2-7]XXX 7[0-47-9]XXX 8[3-5]XXX
The correct data is as follows:
Buxton 1298 2[2-8]XXX 7[0-47-9]XXX 8[3-5]XXX
The part "[2-7]" changes to "[2-8]".
Alton 1420 2[23]XXX 8[02-9]XXX
Alton 1420 2[23]XXX 8XXXX
The part "[02-9]" changes to "X".
St. Austell 1726 6[13-7]XXX 7[0-7]XXX
St. Austell 1726 6[13-9]XXX 7[0-7]XXX
The part "[13-7]" changes to "[13-9]".
The following number range is missing from the table:
Location Area Code 5-digit Subscriber Number Ranges
Penrith 1768 88[2-46-8]XX
The above number range needs to be added to the table.
The following area codes changed name in 2003:
  • 01461:  Annan            changed name to  Gretna.
  • 01488:  Great Shefford changed name to  Hungerford.
  • 01562:  Stourbridge     changed name to  Kidderminster.
  • 01744:  Rainford          changed name to  St Helens.
  • 01963:  Templecombe  changed name to  Wincanton.
There's a spelling mistake in the table:
  • 01557:  Kircudbright  should be Kirkcudbright.
Correct the spelling for this area.
A new section is needed, listing the details of 4-digit subscriber numbers:
Appendix E - Four-digit Subscriber Numbers
5-digit Area Codes with Mixed 4-digit and 5-digit Subscribers
Numbers beginning either 0169772 and 0169773 are in a 5-digit code area and have a 4-digit subscriber number:
A new table is needed as follows:
Location Area Code 4-digit Subscriber Number Ranges
Brampton 16977 [23]XXX
Add a new table to show the data for this number range.
* Originally posted 2011-12-01. Minor corrections and additions 2012-01-05.
