Remote Telnet access to Switches
Dec 5th, 2007
Hi all
I have a network in another country. May i know what do i need to configure so that I can have remote telnet access to the router and switches outside the country that the network is located.
An Example of the network would be
ISP Cloud --- Router --- Switches
Presume I dun have any firewall. How do i configure so that I can have telnet access to the router and switches for troubeshooting. THanks in Advance.
bvsnarayana03 Wed, 12/05/2007 - 21:56
Firstly you need to set local username & password on all devices.
username XXXX password xxx
Then you'll have to enable telnet for access from remote by command:
line vty 0 4
if you have acs then you may set your devices to be authenticated by aaa.
caijunjie Thu, 12/06/2007 - 05:37
Thanks. If my switch is behind a router. I have no problem accessing the router through the WAN IP configured.
Question is how do i access the switch. What IP should I telnet to and from where ?
Please help. Thanks
bvsnarayana03 Thu, 12/06/2007 - 05:53
With the Vlan management IP. You must be having 1 management Ip on the switches by which you telnet & manage the switches.
Hope that clarifies.
pls rate all helpful posts.
