Mitel to CIC Communication through a Cisco SIP to QSIG GW
Dec 6th, 2007
W have a customer who is trying to link a CIC SIP CallCentre to the existing Mitel SX2000 voice network using a Cisco 3800 series gateway. The Mitel is connected into the Gateway using QSIG, with the CIC system using SIP to the gateway in order to call the Mitel system.
This works in part... If we make a call from the QSIG Side (Mitel) to the SIP side (CIC) then the call is established and works fine. If we make a call the other way (SIP to QSIG) it fails. The phone actually rings, but when you pick up the phone, you still hear ring tone in the originating phone, which is a signalling issue from QSIG to SIP.
If we enable debugs, we can see the message coming back from the QSIG side to say that the handset has been picked up, but we never see a similar message go out to the SIP side from the gateway.
Has anyone come across this or a similar issue before?
Mark.
paolo bevilacqua Thu, 12/06/2007 - 03:51
  • Hall of Fame,
    Founding Member
can you include the debug isdn q931 output please.
m.newbould Thu, 12/06/2007 - 04:07
Thanks for the reply.
Unfortunately I don't have a copy of that debug at the moment. I will try and get hold of it and attach it.
Mark.
johncaston_2 Sun, 11/14/2010 - 13:25
Did you ever get this resolved?
I'm trying to do a similar thing, that is CIC via SIP to Cisco Gateway to CUCMv7.1 (H323) and I have exactly the same issue as you described; I can call from the CUCM to the CIC system fine but not the other way (same result as you descibed)
Any ideas?
Cheers,
John
Felipe Garrido Wed, 11/17/2010 - 07:07
  • Cisco Employee,
It's possible that there may be a delayed offer/early offer to fast start/slow start interop issue. Can you collect the following debugs for a failed call from the voice gateway.
debug ccsip message
debug h225 asn1
debug h245 asn1
debug h225 q931
debug voip ccapi inout
Also, please include the current running configuration of the gateway.
-Felipe
