Hub and Spoke IPSEC VPN
Dec 6th, 2007
I have Cisco 7206VXR VPN concentrator at DC and Cisco 1841 router at my 100 remote offices. I want to establish Hub and spoke ipsec vpn, where my remote office ipsec tunnels will terminate to VPN Concentrator at DC.
I need advise on
1) should i go with static ipsec tunnel configuration at VPN concentrator for each remote office or
2) should i configure the dynamic ipsec tunnels at VPN concentrator to all my remote offices, If i have to configure the dynamic ipsec tunnels at VPN Concentrator, can you share the configuration sample
Help is appreciated.
Paolo Bevilacqua Thu, 12/06/2007 - 05:14
search CCO for "dmvp white paper". All the configurations are in there. recommend you get and HW VPn accelerator also.
ravisambaji Fri, 12/07/2007 - 03:31
Thanks, i did search for DMVPN but iam finding the info like MGRE over IPSEC, but i just want hub and spoke IPSEC configuration for ios based platform, which iam not finding it.
