E1 /T1 Config
Dec 6th, 2007
Hai all,
One of my customer is facing the issue in IPLC (Ind to US ) ..india end its E1 ..were Us end is T1 ...Customer dont want to club 2 T1 to give E1 Output at US end ..
Is this setup possible ..if so what shud be the config at both router ..
Thanks in advance
Lijesh.N.C
paolo bevilacqua Thu, 12/06/2007 - 05:48
  • Hall of Fame,
    Founding Member
most likely you will have full T1 in the US, and 24 timeslots E1 in India.
controller e1 x/y
channel-group 0 timeslots 1-24
CSCO10758684 Thu, 12/06/2007 - 21:40
Hai,
Thanks for the reply.
This is what the config what i did, Even though link is not up
India:
Controller E1 XXX
channel group 0 time slot 1 - 24
framing NO-CRC4
Line code HDB3
Clock source line
USA
Controller T1 XXX
Channel group 0 time slot 1-24
(can you get me what should be the rest of configuration in USA end)
Lijesh.N.C
CSCO10758684 Fri, 12/07/2007 - 04:29
Hai All,
Can any one help me regarding this ..
Config (framing NO-CRC4
Line code HDB3
Clock source line ) ...is modem config
Lijesh.N.C
