Regarding reboot of PIX 535
Dec 6th, 2007
We have PIX 535 in A/A mode.Now in admin context mode CPU utilization was 99%.
All of a sudden PIX got rebooted.
After that it stabilizes to 2%.
Can anybody tell why it might have happened?
Secondly is it recommended to reboot PIX if we observer high CPU utilization.
Can we get any supported doc stating reboot of PIX if CPU utilization go high
Vaishali
Overall Rating: 5 (1 ratings)
ccbootcamp Thu, 12/06/2007 - 08:51
  • Gold, 750 points or more
I had some issues with 7.0 similar to the ones you are seeing but with a pix515e. I thought it was a bug in the code (and I was probably right). I upgraded to 7.2 and it went away.
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
Patrick Iseli Thu, 12/06/2007 - 09:52
Apart of a bug it could also be caused also by heavy logging.
How does look your logging setup ?
Do you log on an external syslog server ?
If yes at witch logging level.. info, warn etc.
sincerely
Patrick
vaishali.nagpure Thu, 12/06/2007 - 20:39
Following commands are used logging
logging enable
logging timestamp
logging standby
logging monitor informational
logging trap notifications
logging facility 19
There is external logging server on one of our DMZ.
Vaishali
