Maximum IPSec/GRE tunnels
Dec 6th, 2007
Hi All
I found some VPN Performances table for Cisco routers saying that: for exemple 870 series router can support about 10 standard IPSec tunnel. A 1841 with Onboard VPN can support about 100 standard IPSec tunnel. A 3825 with AIM-VPN/SSL-3 can support about 2000 standard IPSec tunnel.
But what about IPSec/GRE tunnel ?
Must I divide those values by 2 ?
I found nothing about that. Can someone help me with this.
Thank you very much !
Overall Rating: 3 (1 ratings)
roluce Thu, 12/06/2007 - 09:43
I can say that we haven't seen an issue with GRE being a limiter for GRE/IPSec. An 831 can only do 10 IPSec connections concurrently, and you can run 20 GRE tunnels at the same time from that 831.
In other words, I don't believe there is a direct connection. GRE is a software process, so you would have an issue with CPU or memory, but I don't believe that there is a set limit, or any limit in combination. (none that we've seen)
Rob Luce
netadmindetail Tue, 12/11/2007 - 05:07
How many 831 do you have as spokes ?
Are you running DMVPN network ?
Martin
