Does anyone else have trouble with PAT of SSH (Tcp port 22)?
Dec 6th, 2007
(this is dup. of a message that I posted in the WAN forum, but perhaps this is a better forum to ask in...)
I have two routers, one with a public IP (xxx.xx.xx.23) WAN port and the second one with a private IP connected up to the first router. I want to set up PAT on the first router so I can SSH to the second router. Since I already SSH to the first router, I thought I'll just pick some other port number other than 22 and do a port translation with a "ip nat inside source static" config line doing a TCP port translation from port 2222 to 22 SHOULD work, but it doesn't. (I'm using PuTTY as a client and I can change the port used to whatever I want).
This is in a test environment, I don't have any access-lists or anything else which might be blocking either port 22 or my (arbitrarily picked) port 2222
If I TELNET to my first router and set up my "ip nat inside source static" config to do port 22 to port 22, it works, but port 2222 to port 22 does not work. Very odd.
Router 1 config:
! Last configuration change at 10:24:22 MST Wed Dec 5 2007 by thomasdzubin
! NVRAM config last updated at 13:45:17 MST Thu Nov 29 2007 by thomasdzubin
version 12.4
no service pad
service password-encryption
hostname temp192168
boot-start-marker
boot-end-marker
logging buffered 100000
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxx
no aaa new-model
clock timezone MST -7
clock summer-time MDT recurring 2 Sun Mar 2:00 1 Sun Nov 2:00
ip cef
ip domain name fping.com
username thomasdzubin secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description WAN link (public IP address)
ip address xxx.xx.xx.23 255.255.255.128
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Vlan1
description inside LAN address
ip nat inside
ip route 0.0.0.0 0.0.0.0 xxx.xx.xx.1
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source static tcp 192.168.1.99 22 xxx.xx.xx.23 2222 extendable
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
exec-timeout 60 0
login local
transport input telnet ssh
scheduler max-task-time 5000
end
Router2 config:
MyRouter#show run
Building configuration...
Current configuration : 877 bytes
version 12.4
no service pad
hostname MyRouter
boot-start-marker
boot-end-marker
logging buffered 99999
no aaa new-model
ip cef
no ip domain lookup
ip domain name router.local
username router privilege 15 password 0 router
interface Loopback0
no ip address
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip address 192.168.1.99 255.255.255.0
ip route 0.0.0.0 0.0.0.0 192.168.1.1
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login local
end
Overall Rating: 2 (1 ratings)
lgijssel Thu, 12/06/2007 - 09:35
Interesting problem, well documented too.
My feeling is that this has to do with PAT for the entire subnet running on the router also. In my opinion there are two possible solutions (or things to try)
1: The public subnet is a /25. This leaves plenty of adress space so there is no need to use the first router's interface ip for this.
You can simply pat tcp port 22 with source ip (XX+1) to tcp 192.168.1.99 22. This should certainly work and besides, I dislike configuring a combination of static and dynamic PAT on the same interface ip because it can deliver odd results. I believe this case may well serve as an example for what I mean with that.
2: Your argument against the above might be that ip adress space is growing scarce and that you do not want to sacrifice a public ip for this. You might try what happens when you exempt 192.168.1.99 from global NAT. Modify acl 1 for as follows:
access-list 1 deny 192.168.1.99
I know, (honestly) this should not make any difference but still my suggestion is that you give it a try. ;-)
Please let me know your results.
regards,
Leo
thomasdzubin Thu, 12/06/2007 - 11:00
Thanks, but the /25 subnet is actually only available at my own site where I've reproduced the problem with my test kit. My client that has the real problem only has one public IP, so unfortunately PAT is the only way to go. This is a really strange problem since I use PAT for all sorts of other services... it just fails on SSH so I think there must be something within the SSH protocol that just isn't translating.
