12-06-2007 09:35 AM
I faced with a problem in a solution as follows :
+ The task is about using a module NM 16-A ( It is Not NM 16-A/S ), to obtain a console connections from a Router 2811 to another Router 2811 too.
+ I used a Configuration from Cisco site , Using this URL :
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a008014f8e7.shtml
But it did'nt work , it gave me (( Connection refused by a remote ... ))
when I put the router hostname , or ip and port no
+ I put these configuration as follows:
Router (1)
ip host 3640-1 2001 172.21.1.1
ip host 3640-16 2016 172.21.1.1
ip host 3640-15 2015 172.21.1.1
ip host 3640-14 2014 172.21.1.1
ip host 3640-13 2013 172.21.1.1
ip host 3640-12 2012 172.21.1.1
ip host 3640-11 2011 172.21.1.1
ip host 3640-10 2010 172.21.1.1
ip host 3640-9 2009 172.21.1.1
ip host 3640-8 2008 172.21.1.1
ip host 3640-7 2007 172.21.1.1
ip host 3640-6 2006 172.21.1.1
ip host 3640-5 2005 172.21.1.1
ip host 3640-4 2004 172.21.1.1
ip host 3640-3 2003 172.21.1.1
ip host 3640-2 2002 172.21.1.1
interface Loopback1
ip address 172.21.1.1 255.0.0.0
line 1 16
session-timeout 20
no exec
exec-timeout 0 0
Router (2)
I Did'nt add any configuration except the enable password and the enable secret .
+ The questions is :
- does there is any additinal configuration ,which I must add to make the system work ??
- could I add some configuration to the second router to change the situation ??
- Does any of you have any good documents helping in this situation ???
Please it is Urgent ,
Thank you for your help ,
12-06-2007 10:07 AM
Hi, try "transport input telnet" under "line".
12-08-2007 12:42 PM
But the command line under the con and line does no accept the command
it is only accept the commands
transport output
OR
transport preferred
I'm using version 12.4(8)T IOS
what I have to do
THANKS
12-06-2007 10:52 AM
If a raw TCP stream is required, the port is 4000 (decimal) plus the decimal line number. The raw TCP stream is usually the required mode for sending data to a printer.
I could be wrong but from very long ago I remember having done this using ports in 4000 range.
regards,
Leo
