AP350 Slow Down
Dec 6th, 2007
How many devices can an AP350 handle at the same time before loosing ThruPut? Are all of the following: Ethernet Clients, Repeaters, APs, WGBs, DS Nodes defined as devices?
Thanks in advance.
Overall Rating: 3 (1 ratings)
drolemc Fri, 12/14/2007 - 07:13
  • Silver, 250 points or more
I would suggest not to have more than 15 clients on the AP if you want to get the highest throughput. It also depends on the type of application that you are running on the network. If you are running less bandwidth intensive applications you can have more clients.
