12-06-2007 11:33 AM - edited 03-15-2019 07:39 AM
SRST is confirmed working, each phone seems to be registering fine. Inbound calls work fine as well, however, outbound when the first digit is dialed '9' it immediately gives a busy signal. Any advice on this is greatly appreciated. Thanks!
dial-peer voice 100 pots
incoming called-number .
direct-inward-dial
port 0/2/0:23
dial-peer voice 101 pots
description Emergency Services
destination-pattern 911
port 0/2/0:23
forward-digits 3
dial-peer voice 102 pots
destination-pattern 9911
port 0/2/0:23
forward-digits 3
dial-peer voice 103 pots
description Local Calls 10 Digit
destination-pattern 9[2-9]..[2-9]......
port 0/2/0:23
forward-digits 10
dial-peer voice 104 pots
description Long Distance
destination-pattern 91[2-9]..[2-9]......
port 0/2/0:23
forward-digits 11
dial-peer voice 105 pots
description International
destination-pattern 9011T
port 0/2/0:23
prefix 011
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
timeouts ringing 30
ip source-address 172.16.96.1 port 2000
max-ephones 36
max-dn 72 dual-line
access-code pri 9 direct-inward-dial
voicemail 97064471399
no huntstop
call-forward busy 97064471399
call-forward noan 97064471399 timeout 20
moh Kenny-G-Track-1.wav
multicast moh 239.1.1.1 port 16384 route 172.16.96.1 10.1.1.1
time-zone 13
12-06-2007 12:03 PM
Do you have one of the following depending on your version of IOS?
For Cisco IOS® Software Release 12.3(13)T or earlier:
R(config)#call application alternate default
For Cisco IOS® Software Release 12.3(14)T or later:
R(config)#application
R(config-app)#global
R(config-app-global)#service alternate Default
Hope this helps. If so, please rate the post.
Brandon
12-06-2007 01:08 PM
Double check and found that it is in the config... Is there anything else?
Thanks!
12-06-2007 01:13 PM
How about "ccm-manager fallback-mgcp"?
Brandon
12-06-2007 01:17 PM
Here is most of the config, which does have the ccm-manager fallback-mgcp.
application
global
service alternate default
controller T1 0/2/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
interface Loopback0
description MoH for SRST
ip address 10.1.1.1 255.255.255.255
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.252
encapsulation dot1Q 252
ip address 172.16.239.5 255.255.255.0
ip pim sparse-dense-mode
interface FastEthernet0/1
description Connection to LAN
ip address 172.16.96.1 255.255.240.0
duplex full
speed auto
interface Serial0/2/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
router eigrp 100
network 172.16.0.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 172.16.239.1
no ip http server
no ip http secure-server
ip tacacs source-interface FastEthernet0/1
logging history size 500
logging trap critical
logging 172.16.16.48
snmp-server community backoff RO
snmp-server community anyone RW
snmp-server location Appling Main Data Closet
snmp-server contact Information Technology
snmp-server enable traps tty
snmp-server enable traps frame-relay multilink bundle-mismatch
tacacs-server host 172.16.16.47
tacacs-server directed-request
tacacs-server key xxx
control-plane
voice-port 0/2/0:23
echo-cancel coverage 32
voice-port 0/1/0
voice-port 0/1/1
ccm-manager redundant-host 172.17.16.2
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 172.17.16.3 172.17.16.2
ccm-manager config
mgcp
mgcp call-agent 172.17.16.3 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp validate call-agent source-ipaddr
no mgcp fax t38 ecm
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/1
mgcp bind media source-interface FastEthernet0/1
mgcp profile default
sccp local FastEthernet0/1
sccp ccm 172.17.16.2 identifier 2 priority 2 version 4.1
sccp ccm 172.17.16.3 identifier 1 priority 1 version 4.1
sccp
sccp ccm group 100
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 10 register CFB000ab82d4ba9
dspfarm profile 10 conference
description Remote_Site_Conferencing
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
shutdown
service mgcpapp
destination-pattern 9T
direct-inward-dial
timeouts ringing 30
max-ephones 36
max-dn 72 dual-line
no huntstop
time-zone 13
vm-integration
pattern direct 2 CGN *
pattern ext-to-ext no-answer 5 FDN * CGN *
pattern ext-to-ext busy 7 FDN * CGN *
pattern trunk-to-ext no-answer 4 FDN * CGN *
pattern trunk-to-ext busy 6 FDN * CGN *
12-06-2007 01:16 PM
As your pots dial-peers already have a trunk access code, the command 'access-code pri 9 direct-inward-dial' under call-manager-fallback is not necessary.
Please try removing the command and see if this helps.
Allan.
