LWAP Console Access
Dec 6th, 2007
Good Day!
I am aware of the controller command "config ap username 'user' password 'pass' all/cisco ap"
However I am wondering if it is possible to actually get a login prompt from the lwap console. Entering the command specifies a username, however you are not prompted for the username from the lwap console. I realize that you are a privilege 1 user, however I would like to prevent access from the Lwap console port completely.
Anyone know if this is possible?
drolemc Fri, 12/14/2007 - 07:14
This can be done by creating a local user database on the AP and then enabling login authentication. You will have to use the same commands as that of the router for enabling login authentication.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
