E1 with 79xx DOD...can I have ext with other range like 5xx
Dec 6th, 2007
I am connecting CCM to H323 VGW with E1 have 21279xx DOD range .The phone which have ext 79xx can only call outside . Is it possible to allow phone with other ext like 5xx to use this E1?
rob.huffman Thu, 12/06/2007 - 14:25
Hi Yousif,
Sure, we use numbers in the 5xxx,6xxx,7xxx and 8xxx all on a "shared" T1-PRI infrastructure :)
Hope this helps!
yhab_dataconsult Fri, 12/07/2007 - 08:53
Hi Huffman,
pleasae find attached a copy from my vgw config and two debug files for two call as below:
1-calling nuber from ext 501"debug-callingnumber 501.txt "
2-calling number from ext 7901 -same range of E1- ""debug-callingnumber 7901.txt
the calls from 5xx not work but when I use 79xx ext it work with me.
is there way to change the Calling nuber to the one from Service provider "79xx" without change the ext "5xx"
allan.thomas Fri, 12/07/2007 - 18:05
If all you DNs are 5xx and the last two match the DID 79xx, then you can create a single voice translation-rule and apply it to a profile for your outgoing pots dial-peer:-
voice translation-rule 2
rule 1 /5/ /79/
voice translation-profile outgoing
translate calling 2
dial-peer voice 1010 pots
translation-profile outgoing outgoing
description local
destination-pattern [24]......
no digit-strip
port 0/0/0:1
This wil translate the 3 digit calling party DN 501 to 7901.
Hope this helps
