Which router should i use?
Dec 6th, 2007
Sorry helping out a friend here. I was wondering if anyone can suggest a router that would be good enough to support a small business network. The network has 4 subnetworks. We have four switches these are Cisco Catalyst 2960-24TT 24 port Switch. I want to connect these to a router but I am not sure which would best fit the situation.
davecisco Thu, 12/06/2007 - 14:33
Though the SO/HO is probably cheaper we always use 2801's for out clients networks. You can use 4 port HWIC's to add networks or simply do router on a stick with switches.
