ccbootcamp Thu, 12/06/2007 - 14:40
  • Gold, 750 points or more
Do you have the two switches connected to each other with a stacking cable?
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
whiteford Thu, 12/06/2007 - 14:48
Sorry this is a new area for me, I haven't linked them yet, I thought I could use and ethernet cable.
ccbootcamp Thu, 12/06/2007 - 14:50
Use the stacking cable. You'll have better thoughput and you can manage both switches from one switch. then you can configure VTP, vlans, whatever, and you'll be all set.
-brad
www.ccbootcamp.com
williamsdo@si.edu Thu, 12/06/2007 - 14:50
  • Bronze, 100 points or more
If you use ethernet make sure you make the port a trunk link so it will carry data for all vlans configured on your switches.
whiteford Thu, 12/06/2007 - 22:51
Hi, what are the commands to configure the trunk ports on those switches?
williamsdo@si.edu Thu, 12/06/2007 - 14:48
Hi, you can use VTP and setup a VTP domain server switch and VTP client on the second switch. This will make vlan management easier because th vlan changes you make on the server will be mirrored on the client switch. You will still have to add the switchport to assigned vlans. VTP work great on large networks but I would use it on small networks also. Click on the link below for config information.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4000/7.3/configuration/guide/vtp.html
