VLAN tagging on a Cisco ASA 5520?
Dec 6th, 2007
Hi, I have a Cisco ASA 5520 and a Cisco 3750 switch. I want to create 3 VLANS (like DMZ's) on this switch and get the ASA to use this via its gigabit port, how can I do this?
Collin Clark Thu, 12/06/2007 - 15:26
There is a physical connection between the fa0/1 on the switch and the ethernet 4 interface on the PIX/ASA.
Switch Configuration
interface FastEthernet0/1
description Connection to PIX Firewall
switchport trunk allowed vlan 100-103
switchport mode trunk
duplex full
speed 100
PIX/ASA Configuration
interface Ethernet4
description Trunk Only! DO NOT CONFIGURE!!
speed 100
duplex full
no nameif
security-level 10
no ip address
interface Ethernet4.100
description DMZ 100
vlan 100
nameif dmz101
security-level 10
ip address 10.10.100.254 255.255.255.0 standby 10.10.100.253
interface Ethernet4.101
description DMZ 101
vlan 101
nameif dmz101
security-level 10
ip address 10.10.101.254 255.255.255.0 standby 10.10.101.253
interface Ethernet4.102
description DMZ 102
vlan 102
nameif dmz102
security-level 10
ip address 10.10.102.254 255.255.255.0 standby 10.10.102.253
interface Ethernet4.103
description DMZ 103
vlan 103
nameif dmz103
security-level 0
ip address 10.10.103.254 255.255.255.0 standby 10.10.103.253
HTH and please rate.
husycisco Fri, 12/07/2007 - 01:22
Hi Jorge
Just curious, what happens if Vlan x has 2 ports, one is trunk to ASA and one is trunk to a switch which has member vlans 101-103 through trunk? Should we define vlan IDs of other switch?
Collin Clark Mon, 12/10/2007 - 05:54
Any port that is in that VLAN will be in the DMZ, assuming you have the VLAN on the trunks. Most people have separate switches for DMZ's from internal switches.
