Migrating a Cisco Pix 515 to a ASA 5520
Dec 6th, 2007
I have a Cisco Pix 515 with a quad card, I have ordered a Cisco 5520 as an upgrade. The quad card on the Pix gives me 4 DMZ's, each DMZ port goes into a separate VLAN on a Cisco switch. How would I do this on a Cisco 5520?
JORGE RODRIGUEZ Thu, 12/06/2007 - 15:17
  • Green, 3000 points or more
Andy, the 5520 can support up to 150 virtual lans, you can use for example one 10/100/1000 gig port and use dot1q trunk downstream to a DMZ switch and have for example your 4 DMZ vlans each with differrent security levels.
http://www.cisco.com/en/US/docs/security/asa/asa70/configuration/guide/intrface.html
Jorge
pls rate any helpful post
