Can't connect to NAT'd address internally
Dec 6th, 2007
I have a public address or 204.50.0.100 that is NAT'd to my internal server of 10.1.1.100. My external clients connect to this server by the 204 address no problem.
The issue is when the internal uses (on a differnt LAN than the 10.1.1.0/24) try to get to it they fail. They are forced to use the DNS name that will always resolve to the 204.50.0.100 address.
Is this a PIX thing that is denying access to it, or is it something else?
Dave
Overall Rating: 4 (1 ratings)
acomiskey Thu, 12/06/2007 - 15:17
Depending on where the clients dns server is you can do dns doctoring in the pix.
The other option, depending on exactly how the pix is configured and what version is on it, would be destination nat or hairpinning.
Are the clients and server on different interrfaces? What pix os?
davecisco Thu, 12/06/2007 - 15:21
The DNS is on the Internet (Our service providers DNS). What can I do as per doctoring on the PIX?
PIX 515 with pix711.bin loaded.
How do I do destination NAT or hairpinning and would that effect my external users connecting to it?
Yes the clients and servers are on different interfaces.
Dave
Dave
acomiskey Thu, 12/06/2007 - 19:25
Here is the document on dns doctoring for pix/asa 7.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807968d1.shtml
The alternative hairpinning example is on the bottome. Basically it goes like this...
global (inside) 1 interface
nat (inside) 0 0
static (inside,inside) public.ip private.ip netmask 255.255.255.255
same-security-traffic permit intra-interface
So when your inside clients request the webpage with the public ip, the pix will translate the destination to the private and the traffic will go back out the inside interface to the webserver.
davecisco Fri, 12/07/2007 - 07:32
Hmmmm here is what I have and what I added.
access-li 101 ext per ip any host 204.50.0.100
static (inside,Outside) 204.50.0.100 10.1.1.100 netmask 255.255.255.255
static (inside,inside) 204.50.0.100 10.1.1.100 netmask 255.255.255.255
Still not working. A trace from my PC ends with the PIX?
Dave
acomiskey Fri, 12/07/2007 - 07:37
You would need to add something like...
nat (inside) 1 0.0.0.0 0.0.0.0
davecisco Fri, 12/07/2007 - 07:40
I already have this as it is a live system with many functioning clients behind it:
global (Outside) 10 interface
nat (inside) 10 0.0.0.0 0.0.0.0
If I add the lines you mention will it affect the rest of my config?
Dave
acomiskey Fri, 12/07/2007 - 07:44
Then you should just need to add....
global (inside) 10 interface
That should not affect anything else.
davecisco Fri, 12/07/2007 - 07:50
Trace still ends at PIX, and can't connect to web page?
Dave
acomiskey Fri, 12/07/2007 - 07:55
According to the cisco doc...
"For versions earlier than 7.2(1), it is required that at least one arm of the hairpinned traffic (inbound or outbound) be encrypted. From 7.2(1) and later, this requirement is no longer in place. Both the traffic inbound and the traffic outbound might be unencrypted when you use 7.2(1)."
I assume your problem is you are running 7.1.1. If you don't want to upgrade you could try the dns doctoring solution.
davecisco Fri, 12/07/2007 - 07:59
Thanks allot for your help.
I will look at the doctoring, but probably just upgrade.
Cheers!
Dave
davecisco Fri, 12/07/2007 - 10:26
So I upgraded to 803 and still the same thing.....guess I have to look at the dns doctoring??
Dave
acomiskey Fri, 12/07/2007 - 10:31
That should have worked. Do you want to post more of your config. You didn't have "nat (inside) 10 0.0.0.0 0.0.0.0" in what you posted above, you probably have it and just left it out above?
