CSS11506 Reverse Proxy question
Currently using a CSS11506 in reverse proxy mode. Right now it is handling the front end SSL connection for approx 19 backend web server connections.
I am using 1 Public IP to mask all of these inbound connections via the group command. We are experiencing intermittent
drops client side. Is there a best practice of how many connections the CSS will handle via the NAT process. Is the 20 configured servers a bit to much to be masking via one public IP ?
Cheers
Dave
Gilles Dufour Fri, 12/07/2007 - 02:44
  • Cisco Employee,
Dave,
I would suggest to do some troubleshooting before jumping to conclusion.
The number of servers does not matter.
What is important is the number of connections.
1 connection per server means 20 ports being used and you have 55k available.
So, in this example this is definitely not a problem.
Most of the times, client drops on a CSS are due to the aggressive idle timeout. 16 sec.
So, either you try to bump the timeout with the command 'flow-timeout-multiplier' or you capture sniffer traces showing the drops with couple of show tech and we try to confirm the cause of the problem.
Gilles.
