12-06-2007 10:57 PM - edited 03-03-2019 07:49 PM
i have 3750 switch .can anybody tell me how to check whether it supports POE or not.
MOdel No:: WS-C3750G-48TS-S
Solved! Go to Solution.
12-07-2007 07:28 AM
show power-inline
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12240se/cr/cli2.htm#wp8729716
If you have a PoE switch, it will list all the ports with the allocated power. If you don't have a PoE switch, the command will return with no output.
12-07-2007 12:25 AM
Based on link it doesn't support it
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_data_sheet09186a008016136f.html
Jorge
12-07-2007 01:47 AM
Thanks for your reply.
Is there any command for the same or we have to rely on the data sheets only.
12-07-2007 07:28 AM
show power-inline
12-07-2007 09:29 AM
In addition to Edisons post, the POE switch models are marked with letter P (for POE)
for eg. WS-C3750G-48PS-S
Narayan
