Asa 5505
Dec 6th, 2007
Is it possible to confiure ssl vpn on an asa 5505? We want RDP connection to be visible over ssl vpn? On the remote sites it isn't possible to reconfigure the firewall. We use at this moment asa 5510 as transparent layer 2 firewall, thens isa server 2006 (I think) And want to use the 5505 as ssl/vpn gateway.
Does anyone has a configuration manual to configure the asa as ssl vpn gateway?
Jorg
