PIX translation I want to understand
Dec 7th, 2007
Hello all,
i created a new sub interface on my PIX with the same security level as another one. The option : "enable traffic between two or more interfaces which are configured with the same security levels". on each objects on both interfaces in the NAT on ASDM i see "NO TRANSLATION REQUIRED SAME SECURITY LEVEL COMMUNICATION IS ENABLED" so i don't need to change something but when i create an ACL to allow traffic on one to the other interface ASDM tells me that there is no address tranlastion configured to go to the second interface.
PIX VERSION : 7.0(4) ASDM Version : 5.0(4)
Can you help me ?
Thank you
srue Sun, 12/09/2007 - 06:50
  • Blue, 1500 points or more
can you post the relevant portions of your config?
so you have the following command in your config:
same-security-traffic permit inter-interface
if you have that command configured, you don't need acl's to communicate between the two interfaces.
yann.boulet Sun, 12/09/2007 - 07:09
ok so when this option is enabled you mean that traffic is only routed on each interfaces no acl are needed ? but it seems that i have to allow some traffic...
ok i will send to you the configuration
