max# of ip-phones supported on CME
Dec 7th, 2007
Some documents say that Cisco 3825 running CME supports 168 ip-phones for maximum.
Is 3825 running CME supported when 168 ip-phones regists into the 3825 and every ip-phone has two or three DNs?
Is there any restriction about number of DNs for CME?
Overall Rating: 5 (1 ratings)
allan.thomas Fri, 12/07/2007 - 02:04
  • Blue, 1500 points or more
There are certainly restrictions for the number of DNs supported on your platform.
Take a look at the document at the following link:-
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme403sp.htm
The document states that the 3825 supports 500 ephone-dns which should be sufficient for requirements.
Alternatively, another way of checking is form under the Telephony Service, run the command 'max-dn ?' or 'max-ephones ?', these will also show the maximum.
Hope this helps
Allan.
allan.thomas Mon, 12/10/2007 - 03:39
Hi Tetsuo, no problem all part of the service, thank you for the rating.
Best regards
Allan.
Best Regards
Allan.
