CUSM 2.01: trap generation
Dec 7th, 2007
Hi folks!
Where I can find the snmptrap sent to the CUOM server?
There is a log file? Maybe it's trapgen.log?
If this log is empty and the threshold was excedeed, where I can debug the problem?
Thanks in advance
Leonardo
didyap Fri, 12/14/2007 - 08:36
You can see the logs in trapgen.log. If this file's threshold gets exceeded then you can manually save a copy of this file to some other location and then create a empty log file with the same name in place of the earlier log file.
Leonardo Roberto Sat, 12/15/2007 - 05:41
yes thank you, but I would like to know the local CUOM log file.
The CUSM is in another server.
