CCS11050 High CPU.
Please can you help me identify what is causing high CPU on a CSS11050 device?
Details of device are -
chdccss01# sh ver
Version: ap0610306s (6.10 Build 306)
Flash (Locked): 4.01 Build 2
Flash (Operational): 6.10 Build 306
Type: PRIMARY
Licensed Cmd Set(s): Standard Feature Set
Secure Management
chdccss01# sh chassis
Configuration for CSS 11150:
Name: CSS 11150 SW Version: 6.10 Build 306
HW Major Version: 03 HW Minor Version: 0
Serial Number: 21480063243
Base Mac Address: 00-10-58-03-50-45
Module Number Module Name Status
1 FEM primary
2 FEM primary
5 SCFM-PLUS primary
Port Number Port Name Status
1 e1 online
2 e2 online
3 e3 online
4 e4 online
5 e5 online
6 e6 online
7 e7 online
8 e8 online
9 e9 online
10 e10 online
11 e11 online
12 e12 online
13 e13 online
14 e14 online
15 e15 online
16 e16 online
chdccss01# sh system-resources
System Resources:
Installed Memory: 134,217,728 (128 MB)
Free Memory: 20,833,744 (19 MB)
CPU: 98%
Buffer Statistics:
Buffer Pool: 0
Size: 256 Total:1000 Available:1000 Failures: 0 Low Buffer Count: 688
Buffer Pool: 1
Size:1600 Total:9000 Available:8128 Failures: 0 Low Buffer Count: 7585
chdccss01#
Gilles Dufour Fri, 12/07/2007 - 06:02
do the following.
go to debug mode - command is 'llama'
load symbol-table.
execute cpu hog.
Press 'd' several times to get a list of active processes.
then do unload symbol-table.
gduf-css11000-1(debug)# symbol-table load
Loading string table... 583,460
Loading symbols........ 21,561
Load complete.......... 1,100,924
gduf-css11000-1(debug)# cpu hog
CPU Hog Debug Options
d) Display data
Please enter selection [q=Quit]:d
Checking CPU Hog
TID Name Milliseconds
0x836d92e0 PingKal 0
0x8768b4b0 tASSync 0
0x8375e5f0 AS_00000080.I 0
0x8584d3a0 consoleOB 0
0x876b9bc0 apRdyActvLed 0
Gilles Dufour Fri, 12/07/2007 - 07:12
all these processes are responsible to handle traffic.
Seems like you have reach some limit.
Get a 'flow stat' from llama mode so we can see amount of connections.
Gilles.
Thanks Giles,
Details are -
chdccss01(debug)# flow statistics
Flow Manager Statistics:
Cur High Avg
UDP Flows per second 22 502 15
TCP Flows per second 42 310 39
Total Flows per second 64 624 55
Hits per second 0 0 0
Number of Allocated Flows (non-purged) 3451
Number of Free Flows 94853
Number of Flow Drops 0
Max Number of Flow Control Blocks 159359
Number of Flows with SynAckPending 83
Accumulated Port Flow Statistics:
Current Number of Active Flows 3474
Total Flow Accounting Reports received 25690664
Total Out of Sequence Packet Received 165
Total Spoof Queue Mis-Hits 0
Port CE Active Total Acct TCP UDP Rst FCBs
#e1 1f00 2 7 5 2 0 0 15231
#e13 3001f00 1290 12715311 12714022 1027 263 0 26216
#e14 3401f00 0 12125 12121 0 0 0 26195
#e15 3801f00 1296 6241815 6240727 1171 125 0 26211
#e16 3c01f00 886 6722438 6723789 757 137 0 26214
chdccss01(debug)#
Cheers,
Colin
Gilles Dufour Fri, 12/07/2007 - 15:11
Colin,
that's not that much of flows, but it depends what kind of rules you have.
Any L7 rule ?
Do you have some acl logging ?
Do you have a lot of keepalives ?
I can confirm the processes consuming the cpu are the ones handling the traffic.
So, this box is running at its max.
Gilles.
Gilles,
Thankyou for the information. As a result we looked at the traffic flow in more detail through the CSS and it appears that we have some type of looping FIN/ACK traffic which is generating high volumes of small packets.
When this traffic is blocked the CSS CPU returns to normal (4-5%).
Thankyou for your assistance.
Kind Regards,
Colin.
