Call Park Disconnects
Dec 7th, 2007
I am having problems with the call park feature disconnecting once the person has been parked. The system will hold the call for around 30 seconds and hang up. We have a 2811 Router with CME installed and it is running version 12.4 (4) T2. We had a problem with the router and it was replaced about one week ago but the software and flash information is still the same. Any Ideas?
carenas123 Fri, 12/14/2007 - 08:37
  • Silver, 250 points or more
In order to resolve this issue, disable the Advertise G.722 Codec Cisco CallManager Enterpise Service Parameter, and reset the device pools that contain these phone types.
allan.thomas Fri, 12/14/2007 - 14:08
  • Blue, 1500 points or more
Have you verified whether the configuration for the call-park DN has not changed? Have you specified a timeout interval for the DN?:-
ephone-dn x
number xyz
park-slot timeout 10 limit 3
For example, a timeout interval of 10 seconds and a limit of 3 timeout intervals will park calls for approximately 30 seconds.
If the above is the case then you could try either increase either the timeout or limit accordingly. Alternatively you could use recall, which returns the call to phone that originally parked it after the timeout interval:-
ephone-dn x
number xyz
park-slot timeout 10 limit 3 recall
Hope this helps.
Allan.
astanislaus Wed, 09/02/2009 - 19:02
Is there a solution to this site. We are seeing teh same problems at mutiple site with mutiple model CME routers.
Cisco IOS Software, 3800 Software (C3845-ADVIPSERVICESK9-M), Version 12.4(20)T1, RELEASE SOFTWARE (fc3)
and
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(15)T5, RELEASE SOFTWARE (fc4)
Partial Config:
========ephone-dn 100
number 501
park-slot timeout 60 limit 5 notify 602 recall
label Park 501
ephone-dn 101
number 502
label Park 502
ephone-dn 102
number 503
label Park 503
