Gigaman with a 3845
Dec 7th, 2007
I'm going to be getting a Gigaman link from AT&T next week and I'm wondering if there is a module for the 3845 I can get? Do I really need to get a switch to go between the router and gigaman or is there a module?
Answers are appreciated.....
Overall Rating: 5 (1 ratings)
Edison Ortiz Fri, 12/07/2007 - 07:20
  • Hall of Fame,
    Founding Member
Find out from the ISP what kind of hand-off are they going to provide.
If it's copper, you can connect it directly to the 3854 LAN ports, no need to purchase an additional module.
If it's optical (fiber), then you need this module http://www.cisco.com/en/US/products/ps5855/products_data_sheet0900aecd8016be8d.html
