No MTP Resources Available
Dec 7th, 2007
After upgrading CallManager from 4.1 to 4.3 I started getting the No MTP Resources available error message when trying to place a caller on Hold or Transfer. This does not occur if the call is within the CallManager Cluster. It only occurs when a call is place to or originates from outside the Cluster. If I reset the MTP resources the Hold and Transfer functions will work temporarily.
gogasca Sat, 12/08/2007 - 17:38
Did u select G729 as available codec for MOH under IPVMS service parameters?
MTP under ICT or H323 is checked?
Please clarify if MOH and supplementary services works fine.
When u say outside cluster it is for PSTN calls or for ICT calls?
Let us know
Ray Watkins Sat, 12/08/2007 - 19:19
Outside cluster....calls from PSTN or other non-callmanager phone systems in the organization. All of the regions are using G711. I will check the rest of your question Monday and let you know..
Ray Watkins Tue, 12/11/2007 - 08:04
MTP required is checked on the H323 gateway. This not a trunk. The route pattern points to this gateway to connect to the Avaya system and to the PSTN.
Ray Watkins Wed, 08/13/2008 - 12:36
Just to let everyone know. This was a caused by a duplex mismatch on the switch port.
