CSA 5,2.0.238 installed on a Win 2k3 Server
Answered Question
Dec 7th, 2007
The server that I will be deploying with the CSA Agent, should it only be attached to the Group "Servers - Internally Deployed" or should it be joined to other groups as well? This server is not a file or print server but a will maintain logs so i do want the necessary protection.
Adam
Correct Answer by tsteger1 about 9 years 4 months ago
Yes, I don't clone everything like I did with 4.X.
It makes upgrades and management a lot easier IMHO.
Tom
Overall Rating: 5 (2 ratings)
tsteger1 Fri, 12/07/2007 - 09:50
  • Red, 2250 points or more
That and "Servers - All types" sounds like a good start.
If you want to protect or audit the logs, you would need to add a few more rules.
Tom
kerraj2004 Fri, 12/07/2007 - 10:46
Also, instead of nesting groups and such should I just copy the rules from the "Servers - Internally Deployed" and apply them in the copied Group of "Servers - All Types" ?
Thanks Tom,
Adam
tsteger1 Fri, 12/07/2007 - 11:23
Hi Adam, I think that's a matter of personal preference.
In 5.2, I left pretty much everything at the defaults (unlike what I did with 4.X).
My servers are all in the default servers group and in other groups based on their function.
I move all exceptions into custom exception modules in custom policies and associate them with default groups.
Again, that is my personal preference but there are others that do it differently.
Tom
kerraj2004 Fri, 12/07/2007 - 13:48
so you are pretty much using the default groups and creating your exceptions as needed?
Adam
Correct Answer
tsteger1 Fri, 12/07/2007 - 14:14
Tom
