Auto QoS VoIP and video question
Answered Question
Dec 7th, 2007
I need to install IP Camera on switchs already configured with autoqos voip, my cameras mark dscp value with af41,
Is it sifficient to use mls qos trust dscp on camera interface and port trunk?
Port is currently configured with mls qos trust cos, do I need to change it by mls qos trust dscp cause my camera only mark dscp value?
Best regards
Correct Answer by erikjustinlee about 9 years 5 months ago
yes, you will have to add the mls qos trust dscp on that port. Or you can use the mls qos trust device (blah) if you are worried about someone else plugging into that port and taking advantage of your network. Hope that helps.
Erik
Overall Rating: 4 (1 ratings)
Correct Answer
erikjustinlee Fri, 12/07/2007 - 09:14
Erik
