VPN between ASA 5510 and Cisco 1721 router
Dec 7th, 2007
Hi there,
I have a little problem. Advice me to resolve it pls.
I created IPSec VPN between ASA 5510 and Cisco 1721 and those config is following :
ASA 5510 configuration
interface Ethernet0/2
speed 100
duplex full
nameif inside
security-level 90
ip address
ospf cost 10
interface Ethernet0/3
speed 10
duplex full
nameif vpn
security-level 0
ip address
ospf cost 10
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group service TCP_Service_Group tcp
description Well known TCP ports
port-object eq pop3
port-object eq sqlnet
port-object eq ftp-data
port-object eq ftp
port-object eq ssh
port-object eq telnet
port-object eq smtp
port-object eq https
port-object eq www
port-object eq domain
port-object range 5050 5050
port-object eq imap4
object-group service IPSec_Ports udp
port-object eq isakmp
object-group service vpn tcp
port-object range netbios-ssn netbios-ssn
port-object range 445 445
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit tcp object-group vpn
access-list inside_access_in extended permit tcp any object-group TCP_Service_Group
access-list vpn_20_cryptomap extended permit ip
access-list inside_nat0_outbound extended permit ip
ip verify reverse-path interface outside
ip verify reverse-path interface dmz
ip verify reverse-path interface inside
ip verify reverse-path interface vpn
icmp unreachable rate-limit 1 burst-size 1
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 2
nat (vpn) 2
access-group inside_access_in in interface inside
route outside x.x.x.x 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map vpn_map 20 match address vpn_20_cryptomap
crypto map vpn_map 20 set peer
crypto map vpn_map 20 set transform-set ESP-3DES-SHA
crypto map vpn_map interface vpn
crypto isakmp enable vpn
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
tunnel-group type ipsec-l2l
tunnel-group ipsec-attributes
pre-shared-key *
Cisco 1721 routers configuration
crypto isakmp policy 11
encr 3des
group 2
crypto isakmp key cisco123 address
crypto ipsec transform-set 1st esp-3des esp-sha-hmac
crypto map nolan 11 ipsec-isakmp
set peer
set transform-set 1st
match address 120
interface Ethernet0
ip address
ip nat outside
crypto map nolan
interface FastEthernet0
ip address
ip nat inside
speed 100
ip nat pool branch netmask 255.255.255.
ip nat inside source route-map nonat pool branch overload
ip route
access-list 120 permit ip
access-list 130 deny ip
access-list 130 permit ip any
route-map nonat permit 10
match ip address 130
And now, I can access from to any windows share in network network like following:
Start\Run \\
and also Internet access is OK.
And I can access to Internet from, but I can`t access to
For example:
Start\Run \\
Error is "The network path is not found."
Is it clear?
where is problem? What should I do?
Help me pls,
Tnx a lot.
