complex qos
Dec 7th, 2007
Hi guys
i have an campose with 200 users.
they are using dhcp ip address.
i want to give per ip just 128K but if the bandwidth was free they can reach more than 128K
any hint?
cisco_lad2004 Fri, 12/07/2007 - 11:58
u simply need to rate limit at each access port.
I am assuming users in ur Campus are assigned will connect VIA some sort of access switch and in that case u can ( depending on IOS/HW) rate limit or police traffic using a policy map.
Sam
royalblues Fri, 12/07/2007 - 12:32
though as suggested above you can rate limit the traffic, you cannot make them use more than the configured limit at any time.
Narayan
