7921G Phone Call Drops when switching WAPs on Different WLC's
Answered Question
We are having issues with calls getting dropped when a 7921G phone traverses from a WAP that is connected to Wireless LAN Controller A and transfers to a WAP on Wireless LAN Controller B. This is occurring with both of our 4402WLC and 2106 WLC. We have mobility groups enabled and setup and they can ping the other controllers. There is no problems when traversing from one WAP to another WAP that are associated with the same WLC controller. Any ideas where the problem may be?? I'm trying to find information on configuration settings for this but not much information out there.
Correct Answer by john.preves about 9 years 5 months ago
I'm still not sure what happened...were there different Vlans on different trunks?
one more ...are the ssid's in the wlan groups between both controllers pointing to the same interface?
Overall Rating: 5 (2 ratings)
Richard Atkin Fri, 12/07/2007 - 13:50
  • Silver, 250 points or more
Can you tell us what authentication / encryption mechanisms have been deployed?
Thanks.
migilles Fri, 12/07/2007 - 15:26
  • Cisco Employee,
Would encourage to use 4.1.185.0 or 4.2.61.0.
But since no issues w/ intra-controller roaming, seems to be a controller config or bug or network issue.
john.preves Sun, 12/09/2007 - 10:11
sorry, I have to ask the obvious...are these two sets of controllers in the same vlan? You are not attempting to roam between the 4xxx and the 2xxx on two vlans?
Correct Answer
john.preves Sun, 12/09/2007 - 10:14
The SSID's and the WLAN groups are identical on each side. In fact we deleted and recreated them a few times without any luck. The 4402 controllers show the physical interface as LAG and are connected via channel-group on a 4506 controller. The 2206 controllers are connected to a 3750 switch and the physical interfaces are pointing to interface 2. We have a channel-grou setup for each of the 2 gig interfaces on different 4506 controllers (Primary and secondary) to the 4402's. The 2206's connect through a 3750PS Switch and are connected to the same switch. When all the access points are forced to one controller we do not have any issues with handoffs between WAPs. Again it's when they are load balanced that we see this handoff problem.
On your devices and interfaces verify
Core to Core Port Channels - (This is where you have one 4402 or 2106 on one core and one on another core switch)
interface Port-channel1
switchport
switchport trunk allowed vlan XX, XX -- Where XX is your voice, controller and Data Vlans etc..
switchport mode trunk
Core to WLC
interface Port-channel3
description LAG trunk to WLC01
switchport
switchport trunk allowed vlan XX, XX, XX -- Where XX is your voice, controller and Data Vlans etc..
WLC Controller
Also Verify and ensure LAG mode is enabled on the WLC under:
Controller->General->Enable LAG Mode on next reboot
We also updated the phone firmware to the most current release but this did not actually solve the problem.
john.preves Tue, 12/11/2007 - 21:08
I'm pretty sure I didn't understand any of that..so it's probably me, but your phones have the same IP address on them when they were on controller A as they do when they roam to B?
I apologize in advance for my inexperience.
Other than the above, I am over my head.
We are on the same subnet and we haven't setup inter subnet roaming. I haven't checked and this is a good question. We will double check on this. Cisco TAC is getting us to upgrade the phone firmware as it's down two levels. TAC support says all the roaming and traversing information is handled by the phones. We are at version 1.04 and we should be at 1.06. Our callmanager version 5.1.2. We are planning to upgrade the firmware on the phones later today.
switchport
Core to WLC
switchport
WLC Controller
fcoppotelli Wed, 12/12/2007 - 07:13
I had your same problem.After many tests I fixed the situation configuring all the AP's on one WLC and keeping the second one in standby (empty but ready to accept registration if the first fail).
You can configure the order of the WLC's on each AP.
Fabio
pfocas Thu, 12/13/2007 - 10:02
If the break is being caused by a re-authentication, it may be worth trying to use CCKM. This prevents a reauthentication on a roam, and is only supported using TKIP, not WPA2 (I presume you're using AES). I'd use either EAP-FAST or LEAP and CCKM to see if it makes a difference.
Correct Answer
john.preves Thu, 12/13/2007 - 13:01
Richard Atkin Fri, 12/14/2007 - 17:49
Have you ticked the 'Enable Fast SSID Change' option on the WLC under the Controller page?
Richard.
