Cisco 7200 as BRAS
Dec 7th, 2007
does anyone of you know if you can use a Cisco 7200 as a BRAS? We were told it is possible, but I am not able to find an IOS image with PPPoE support.
Any pointers are welcome.
TIA
NaNa
cisco_lad2004 Fri, 12/07/2007 - 12:17
  • Gold, 750 points or more
I have used 3 years ago, it does the job....I cannot recall the exact IOS version. I guess if I did I would be labeled a nerd.
try features/IOS selector to find what u need.
Things to watch out for with 7200...it does not cope very well with VoIP small packets.
sorry I don't have much more to say
Sam
nanacisco Sat, 12/08/2007 - 01:51
uh, sorry.
I mistyped, I am looking for BRAS support in the Cisco 7600, not 7200.
My bad. The 7200 is commonly used as a BRAS, so IOS support is easy to find.
But the 7600 is another story entirely.
So, can the 7600 be a BRAS?
TIA
NaNa
nanacisco Mon, 12/10/2007 - 07:42
Thanks for the tip, but ISG does not support 7600.
As for the SIP-400, it does not support PPPoE.
It seems the only option is to use the MWAM card.
thanks for your tip.
NaNa
