CCVP lab help
Dec 7th, 2007
I bought a 2811 off ebay. I also bought a VIC2-2FXO and VIC2-2FXS. I put them in the 2811 but the 2811 doesn't show any voice ports. Are both VIC cards bad? Is the 2811 dead?
Overall Rating: 5 (5 ratings)
ccbootcamp Fri, 12/07/2007 - 15:01
  • Gold, 750 points or more
Do you have any PVDM2s in your 2811? If not, that's more than likely your problem.
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
swrsmaster Fri, 12/07/2007 - 15:17
Why do I need PVDM2s? I thought those were for transcoding and conferencing? I have a 3640 with NM-2V and VIC-2FXS and it works just fine without any PVDMs.
ccbootcamp Fri, 12/07/2007 - 16:03
The NM-2V has DSPs on the card itself for the voice modules. The VICs that go into the 2811 go directly into the router and not into a network module. Therefore, the 2800 series routers need DSPs (ie, PVDM2s) to see the voice modules.
-brad
www.ccbootcamp.com
swrsmaster Fri, 12/07/2007 - 16:27
Thank you for the explanation. I will try it and see if that will work.
