12-07-2007 08:27 PM - edited 03-03-2019 07:50 PM
What iff, if one switch is running RPVST & the other is running MSTP? What are the compatibility issues or any other thing to consider.
Many thanks in advance.
12-08-2007 09:56 AM
12-10-2007 03:28 AM
if i enable 'spanning-tree mode rapid-pvst' command on Cisco switches, then what will be the behavior? Either RSTP enable or RPVST.
The problem we are facing that when we enable RSTP on Cisco switch & RSTP on Non Cisco switch, bith are not compatible/not working together.
Any idea?
12-10-2007 08:38 AM
The command you posted will enable Rapid Per-Vlan Spanning Tree (RPVST).
Please read the link I provided on compatibilities.
