ospf on 3550 vs 4500
Dec 8th, 2007
Im having the following command on a switch 3550, but when I try now migrating it over to 4500, I cannot get the same command in, can you help me?
router ospf 109
log-adjacency-changes
network 10.56.1.0 0.0.0.255 area 0.0.0.0
Jon Marshall Sat, 12/08/2007 - 05:37
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Jorge
Which bit of the config won't go in, all of it ?
What error message are you getting ?
Which IOS version are you running on the 4500 ?
Jon
jorge.s Sat, 12/08/2007 - 06:41
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12
.2(25)EWA10, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 11-Jul-07 00:08 by dchih
Image text-base: 0x10000000, data-base: 0x114BC038
ROM: 12.2(31r)SG3
Pod Revision 14, Force Revision 34, Tie Revision 32
ITC0004 uptime is 3 hours, 30 minutes
Uptime for this control processor is 3 hours, 30 minutes
System returned to ROM by Stateful Switchover
System restarted at 12:09:46 cet Sat Dec 8 2007
System image file is "bootflash:cat4000-i9s-mz.122-25.EWA10.bin"
cisco WS-C4510R (MPC8540) processor (revision 11) with 524288K bytes of memory.
Processor board ID FOX11140THS
MPC8540 CPU at 800Mhz, Supervisor V-10GE
Last reset from PowerUp
15 Virtual Ethernet interfaces
296 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Edison Ortiz Sat, 12/08/2007 - 10:02
  • Hall of Fame,
    Founding Member
You have a basic L3 image. For OSPF support, you need the enhanced L3 image cat4000-i5s-mz.122-25.EWA10.bin
jorge.s Sat, 12/08/2007 - 11:54
You are right, I didn't upgraded it has I tought.
now should be ok, but how do I configure OSP?
ITC0004#sh ver
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I5S-M), Version 12
.2(25)EWA12, RELEASE SOFTWARE (fc1)
Compiled Thu 15-Nov-07 18:21 by kellythw
Image text-base: 0x10000000, data-base: 0x114BC884
ROM: 12.2(31r)SG3
ITC0004 uptime is 8 hours, 43 minutes
Uptime for this control processor is 7 hours, 54 minutes
System returned to ROM by redundancy reset
System restarted at 12:58:09 cet Sat Dec 8 2007
System image file is "bootflash:cat4000-i5s-mz.122-25.EWA12.bin"
Last reset from Redundancy Reset
ITC0004#
Jon Marshall Sat, 12/08/2007 - 11:58
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jorge
Not sure what you mean about how do you configure OSPF. ?
As per your example in your original post
router ospf 10
network 10.57.1.0 0.0.0.255 area 0
etc.
Jon
