12-08-2007 01:44 PM - edited 03-05-2019 07:53 PM
I am playing with QoS and traffic policies and was hoping someone could set me straight on bandwidth usage. I know QoS reserves 25% bandwidth by default for internal process overhead, but is this actually needed for network traffic? Or just to keep the interface from being too busy?
Example:
Lab router 2514 is connected to the internet on Ethernet0 via 512 Kbps upstream cable modem. Do these 'internal processes' need the actual 128Kbps of the 512? Could I set the bandwidth of the interface to 682Kbps so it has 25% in addition to the 512Kbps of the internet connection as the interface is capable of more then 512?
Any info helps!
John
Solved! Go to Solution.
12-09-2007 11:05 PM
This is something you can decide yourself and it will not be the same for all systems.
For example, it makes quite some difference whether you are using a routing protocol or not.
You can adjust the default by specifying the usable bandwidth per interface using the following interface-command:
max-reserved-bandwidth 96
This example allocates 96% of the bandwith for user traffic.
regards,
Leo
12-09-2007 11:54 PM
HI John, [Do RATE ALL HELPFUL POSTS]
In addition to Leo POST,
25% of Overall Bandwidth is reserved by QOS for Internal Route Processing Traffic like OSPF Updates / Eigrp Update / BGP Updates and other Routing Protocol Updates over WAN / LAN the QOS is implemented.
Do RATE ALL HELPFUL POSTS.
Best Regards,
Guru Prasad R
12-09-2007 11:05 PM
regards,
Leo
12-09-2007 11:54 PM
Best Regards,
Guru Prasad R
12-11-2007 05:07 AM
Thanks guys, that was exactly the information I was looking for. :)
John
12-11-2007 09:00 AM
guru bhai congrats on ur 500.
12-12-2007 04:22 PM
One of other fundamental reasons for this reservation is to ensure that you do not completely starve bandwidth for the scavenging/best effort traffic when you configure your QoS policies.
Allan.
