PRI troubleshooting
Dec 8th, 2007
I remember entering a command once that would show the list of channels of a PRI and whether they were active but can't seem to remember what it was. Does anyone know this command?
-Shikamaru
rob.huffman Sat, 12/08/2007 - 15:35
Hi Shikamaru,
Hope all is well with you! If this is an IOS Gateway you can use this command to show the status of the channels;
Router# show mgcp connection
Hope this helps!
Rob
shikamarunara Sat, 12/08/2007 - 19:20
Hey Rob,
The command I was hunting for was "show voice call summary", which was mentioned by Alan in a post to this thread. Boy that command comes in handy ;)
Thanks again, guys.
-Shikamaru
UCBNOCWAN Mon, 12/10/2007 - 04:57
Hi Rob,
Good afternoon. hope that you had a nice weekend. I need help from you again. This is regarding a query I posted on Friday night. Could you please throw some light on this?
Issue :
When I go to "Tools-> CDR Analysis & Reporting", then "CDR -> Export CDR / CMR" - Export to File. After clicking on the "Export to File" button I get the following error - Error code - 10011. - System error - contact System Administrator"
Is it an authentication issue? I am using my user account. Even the Admin account ( superuser account) doesn't work.
Abhijit Das.
allan.thomas Sat, 12/08/2007 - 15:57
In addition to the command mentioned by Rob, try eithers of the these two commands also:-
'show voice call summary'
'show voice call status'
Allan.
