General Router VPN setup
Answered Question
Dec 8th, 2007
Hello experts,
I need to connect a VPN with my cisco router to a Cisco Asa version 7.2
I need some guidance to see if this configuration looks about right because I'm confused with the phases 1 & 2:
Phase 1 - Required
PROTOCOL encryption: IPSEC
DIFFE - HELLMAN: GRUPO2
Encrypt algorithm: 3DES
Hashing: SHA
Lifetime: 86400 SEGUNDOS
MODe: MAIN
-- I configured:
crypto isakmp key testkey address 1.1.1.1 no-xauth
crypto isakmp policy 21
encr 3des
authentication pre-share
group 2
* sha doesn't appear because I read it is default
* the lifetime is not appearing
Phase 2 - Required
Encapsulation: ESP
Encryption: 3DES
Authentication: SHA
PFS: Group2
Lifetime: 8 Hours
LIfetimeKB: 4608000
-- I configured:
crypto ipsec transform-set test esp-3des esp-sha-hmac
crypto map 3desmap 17 ipsec-isakmp
set peer 1.1.1.1
set transform-set test
set pfs group2
match address acltest
My questions:
1- Is Transform-set phase 2?
2- where do I configure the lifetime of 8 hours?
Correct Answer by srue about 9 years 1 month ago
the transform set is phase 2 (and the isakmp policy is phase 1).
You can set lifetime under the isakmp policy. I believe you can leave it as is, and during negotiation if the two peers differ on lifetimes, it should choose the smallest value.
Overall Rating: 5 (1 ratings)
Correct Answer
srue Sat, 12/08/2007 - 19:52
