icmp command error
Dec 8th, 2007
I have a pix501 software 6.3(4)
Working from the PDM I can bring up the Command line tool and enter the command:
icmp deny any outside
The command works i.e no error message and it appears when I do 'show running-config.
If I try this same command using a console connection direct from a PC I get an error message which tells me to use the help command.
What is going on? why does the syntax work in one place and not the other?
Thanks for any help.
Hugh
Overall Rating: 4 (2 ratings)
husycisco Sat, 12/08/2007 - 17:24
make sure you are in configure terminal mode
firewall>enable
Password:Yourenablepassword
firewall#>configure terminal
firewall(conf)#>icmp deny any outside
leo_7vsta Sun, 12/09/2007 - 11:24
Hi there,
Thanks for the help. I'm new to the Command line. I went into config mode and typed the command for the icmp and got the error that 'entry for address/mask= 0.0.0.0/0.0.0.0 already exits.
I then wondered how to clear it using the terminal console.
I checked the PDM /configuration on the icmp and there I can simply select and delete. However I would like to be able to do this through the terminal console.
how about 'no icmp permit any outside' to remove icmp permit any outside ?
Hugh
husycisco Sun, 12/09/2007 - 11:31
Yes you can can remove it by
But remember, you should be in configure terminal mode as I stated in my previous post
leo_7vsta Sun, 12/09/2007 - 11:52
I already tried it and it worked. I went back in in configure mode.
Thanks again
hugh
husycisco Sun, 12/09/2007 - 14:23
You are welcome Hugh, you can enter previous mode by typing quit or exit.
Please do not forget to rate/accept the post which worked for you
