Identity NAT on PIX -- help needed
Dec 8th, 2007
  • Cisco Employee,
I have read through the documents on Identity NAT but few things are not clear to me. Consider the following network setup and the requirement.
PC1 ----[Inside]-PIX--[Dmz]---PC2
PC1 - 10.1.1.1
Inside - 10.1.1.2
DMZ - 10.2.2.1
PC2 -- 10.2.2.2
Requirement
PC2 has to retain the same IP address when it is communicating with inside network.
So configured following NAT
Static (dmz, inside) 10.2.2.2 10.2.2.2 netmask 255.255.255.255
However, when I configure following statements the traffic flows as expected
Static ( inside, dmz) 10.2.2.2 10.2.2.2
Static ( inside,dmz) 10.1.1.1 10.1.1.1
Static (dmz,inside) 10.1.1.1 10.1.1.1
Question
Can someone explain the identity NAT concept in the above scenario and the correct configuration statement?
Thanks in advance for your time
Padmanabhan
srue Sat, 12/08/2007 - 20:32
  • Blue, 1500 points or more
can you first answer a couple questions about your setup please?
1. what version of PIX OS?
2. if version is 7.x or later, is nat-control enabled
3. what is the security-level of the dmz interface?
padramas Sat, 12/08/2007 - 20:39
  • Cisco Employee,
1- 7.2.2
2- Nat control is enabled
3- Inside 100, DMZ 50
Please let me know if you need any further information or not.
