ACS Upgrade to 4.1 Error Message
Dec 8th, 2007
When trying to upgrade 3.3 to 4.1 I get the following error message:
ODBC Operation faild with the following information: Message=[Sybase][ODBC Driver][Adaptive Server Anywhere]Datatbase page size too big, SqlState=8004, NativeError=-97
Overall Rating: 5 (1 ratings)
j-foote Wed, 01/09/2008 - 08:45
i actually resolved the problem myself. Turns out we were running symantec backup-exec on the server. That version of backup-exec was using an older version of sybase. You can check this by going to data sources in control panel and under odbc drivers, see what is listed. If any older version of sybase is there, you will need to remove. My problem went away by uninstalling backup-exec.
Hope this helps.
James
e233797abc Wed, 01/09/2008 - 11:34
James, thank you for your quick response on this and also for the clue. Since we are installing this ACS 4.1 on the same server as the CiscoWorks LMS 3.0 we had to stop/disable the LMS services before the installation of ACS .... DL
