FWSM SVI
Dec 9th, 2007
Dear all,
i have this problem wiht fwsm, currently we have a data channel between the fwsm and msfc, the svi does not appear in the router routing table as connected, you can not ping the svi from the router side, while the fwsm can ping its interface and the router interface, aslo you can not ping from the fwsm console to the svi of the router ( mangament vlan that is not in the fwsm group) even i have a default route on the fwsm to the next ho (route) plz help
Jon Marshall Sun, 12/09/2007 - 03:44
Can you give some config details and IP addressing.
The SVI on the MSFC, it is showing as down ?
Jon
