three WAN cct
Dec 9th, 2007
we have three WAN ccts (6M ADSL, 10M ethernet and E1 IPLC). all of themn are connected to 4700. I will build the vpn between HK and TW. Also, we have one IPLC between HK and TW.
following is the ip address allocation
1. 192.168.16.0/22 in HK HQ
2. 192.168.132.0/22 in TST
3. 192.168.196.0/22 in TW
I would like to achieve those services, all traffic access destination IP:
1. 192.168.196.0/24 must via IPLC
2. 192.168.197.0/24 must via VPN
3. 192.168.198.0/24, some goes iplc some goes vpn
and
4. 192.168.16.128/25 access 192.168.196.0/24 must go VPN (not IPLC)
5. 192.168.133.128/25 access 192.168.196.0/24 must go VPN (not IPLC)
what config can achieve item 4 and 5 requirement? pls advise
regards,
! router config:
crypto isakmp key xxxxx address 152.x.x.x
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto map mymap local-address FastEthernet1
crypto map mymap 120 ipsec-isakmp
description vpn to TW
set peer 152.x.x.x
set transform-set myset
match address 120
access-list 120 permit ip 192.168.16.0 0.0.3.255 192.168.196.0 0.0.3.255
access-list 120 permit ip 192.168.132.0 0.0.3.255 192.168.196.0 0.0.3.255
interface FastEthernet 0.1
description to 10M ethernet to TST
ip address 192.168.128.1 255.255.255.252
ip nat inside
interface FastEthernet 0.2
description to user segment
ip address 192.168.16.1 255.255.255.0
ip address 192.168.17.1 255.255.255.0 sec
ip address 192.168.18.1 255.255.255.0 sec
ip address 192.168.19.1 255.255.255.0 sec
ip nat inside
interface FastEthernet 1
description to PCCW ADSL (VPN service)
ip address 218.x.x.x 255.255.255.254
ip nat outside
crypto map mymap
interface serial 0
description to TW
ip address 192.168.192.1 255.255.255.252
ip nat pool NAT 218.x.x.x 218.x.x.x netmask 255.255.255.254
ip nat inside source route-map VPN_nonat interface FastEthernet1 overload
route-map VPN_nonat permit 10
match ip address 150
access-list 150 deny ip 192.168.16.0 0.0.3.255 192.168.196.0 0.0.3.255
access-list 150 deny ip 192.168.132.0 0.0.3.255 192.168.196.0 0.0.3.255
access-list 150 permit ip 192.168.16.0 0.0.3.255 any
access-list 150 permit ip 192.168.132.0 0.0.3.255 any
! go iplc
ip route 192.168.196.0 255.255.255.0 serial 0
! some go iplc
ip route 192.168.198.110 255.255.255.255 serial 0
ip route 192.168.198.153 255.255.255.255 serial 0
ip route 192.168.198.166 255.255.255.255 serial 0
ip route 192.168.198.248 255.255.255.248 serial 0
! other traffic should go VPN
aghaznavi Mon, 12/17/2007 - 06:11
  • Silver, 250 points or more
Implement IPsec tunnel between 192.168.16.128/25 and 192.168.196.0/24 and also 192.168.133.128/25 and 192.168.196.0/24 . If you are not familiar the steps use the SDM for configuration.
anitachoi3 Thu, 12/20/2007 - 09:04
I should build VPN
the first is 192.168.16.0 - 192.168.196.0
and ipsec tunnel
the second is 192.168.16.128 - 192.168.196.0
any sample of ipsec tunnel config?
rgds
