SRST problem dialing ACD Option
Dec 9th, 2007
I need Help with SRST services. When the service is up I can make external calls without any problem but if the call is to any ACD service I can't dial any option, any sugestion?
owillins Mon, 12/17/2007 - 06:12
  • Silver, 250 points or more
make sure you have configured queue service .
Tim Smith Tue, 01/22/2008 - 08:09
Hi..
What IOS are you running on your gateway?
Would have to see your config.. but it sounds like it is a DTMF relay issue. Have you got this enabled on your H323 SRST dial peers?
I have seen a bug, where DTMF tones are not passed by the router.. would be worth searching the bug tool for your particular release.
Cheers,
Tim.
