SSL VPN on 1841
Dec 9th, 2007
Dear friends,
This is my environment: a 1841 with 12.4(9)T1 Advanced IP Services. I'm trying to configure SSL VPN on it using SDM 2.4.1. I could install both "Cisco SSL VPN Client" and "Cisco Secure Desktop" versions 1.1.3.173 and 3.1.1.45 (respectively). The problem is I'm trying to configure CSD (clicking on the related button). The window is showed, but completely empty!
Attached to this post I'm sending the contents of my flash memory.
Could you please explain what could be happening?
Regards!
didyap Mon, 12/17/2007 - 12:49
Check for the Java version on your machine in which you are loading CSD, the Java version should be the recommended one. Also reset the browser settings to default and then launch the CSD. If this also does not work try using a different browser.
