ASA 5520 implicit deny
Dec 9th, 2007
i am having issue to with ASA. I am getting the below error when i do packet trace. Please see my config also below.
packet-tracer input inside udp 172.16.21.14 radius 10.50.1.9 radius$
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Additional Information:
Found no matching flow, creating a new flow
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in 10.50.0.0 255.255.0.0 inside
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Forward Flow based lookup yields rule:
in id=0x3f76d88, priority=500, domain=permit, deny=true
hits=23, user_data=0x6, cs_id=0x0, reverse, flags=0x0, protocol=0
src ip=172.16.21.14, mask=255.255.255.255, port=0
dst ip=0.0.0.0, mask=0.0.0.0, port=0
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
running config attached
how can i fix this?
husycisco Mon, 12/10/2007 - 00:38
  • Gold, 750 points or more
try adding this
nat (inside) 0 10.50.0.0 255.255.0.0
