Cisco PIX 515e static question
Dec 9th, 2007
I have two pix 515e firewalls running v7.2(3). They have a similar setup. On one pix outside has a small /29 ip block which routes a /25 and a /27. I've setup two static rules to allow traffic from a lower interface to higher levels. This works no problem. On the other pix however the setup is pretty much the same, with two exceptions. The ip block on outside is /30 And I making use of several VLANs. Strangely enough I don't need to setup required static rules for this to work. No nat is used I am using public ip addresses.
Can anybody explain why this is ?
Thanks in advance,
Toshio
tspoor Mon, 12/10/2007 - 23:15
Hi timkaye,
First off, thanks for attention. I found out, a few minutes ago that "nat-control" seems to be involved. I am little further now and I am going to investigate the problem with my new findings.
Kind Regards,
Toshio
