smothuku Mon, 12/10/2007 - 01:55
  • Silver, 250 points or more
Hi Pandya ,
Can you paste the "show-tech" output of the router.
If possible steps which you are following to test the isdn line.
and "show isdn active " & "show isdn history".
What was the status of ISDN call once the router was booted..
satish
Richard Burts Mon, 12/10/2007 - 05:04
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
The show version is pretty normal and shows that the router started from a power on. If the router is rebooting when you test ISDN it would be helpful to get a show version after that reboot since it is likely to contain helpful information about the cause of the reboot.
I will also note that the code that you are running is pretty old code. While I can not point at a particular code problem at this point, I would suggest that it might be helpful to upgrade to more recent code in which there are many bug fixes as compared to the code version that you are running.
Rick
